Error Makefile [Linux 3.1.1]
for sure i wrong something: always that error (patching the makefile)
starting from a near to empty folder (just the vu makefile and the sources folder)
i executed exactly these commands
./Makefile-vuplus-1.6k
cd bm750/openembedded
git pull
cd ..
cd build
source ./env.source
#i haven't the bm750/build/tmp/work/mipsel-oe-linux/eglibc-initial-2.10-r8.6/eglibc-2_10/libc/manual/makefile and so:
bitbake -c build nano
# after this one i have the error and that makefile so, i patched it, then again
#but at the end always an error
np, i stop here
but thanks for the help
git pull
cd ..
cd build
source ./env.source
np, i stop here
What linux distribution do you use?
I hope Ubuntu .... :)
fedora16 32bit
mmmmmmh......
Ok the problem should be some packages you have into Fedora are too new and updated and SDK needs oldest ones.
With Ubuntu 11.10 I have a correct SDK installation :)
I will ask our coder who uses Fedora ..... I hope he can help you to setup a correct env to to use OE :)
git pull
cd ..
cd build
source ./env.source
np, i stop here
Hi,
i'm really sure that it's from your make version.
try to install the "make" version 3.81.
ipes/libmad/libmad_0.15.1b.bb, do_package)
NOTE: Running task 686 of 2974 (ID: 2971, /home/babachomu/bm750/openembedded/recipes/libgpg-error/libgpg-error_1.4.bb, do_package)
NOTE: the following files were installed but not shipped in any package:
NOTE: /usr/share/common-lisp/source/gpg-error/gpg-error-package.lisp
NOTE: /usr/share/common-lisp/source/gpg-error/gpg-error.lisp
NOTE: /usr/share/common-lisp/source/gpg-error/gpg-error.asd
NOTE: /usr/share/common-lisp/source/gpg-error/gpg-error-codes.lisp
NOTE: Running task 688 of 2974 (ID: 2887, /home/babachomu/bm750/openembedded/recipes/libgcrypt/libgcrypt_1.4.4.bb, do_package)
NOTE: Running task 692 of 2974 (ID: 2466, /home/babachomu/bm750/openembedded/recipes/gnutls/gnutls_2.4.2.bb, do_package)
NOTE: Running task 693 of 2974 (ID: 2418, /home/babachomu/bm750/openembedded/recipes/libvorbis/libvorbis_1.2.3.bb, do_package)
NOTE: Running task 694 of 2974 (ID: 2694, /home/babachomu/bm750/openembedded/recipes/liboil/liboil_0.3.15.bb, do_package)
NOTE: Running task 696 of 2974 (ID: 2004, /home/babachomu/bm750/openembedded/recipes/gmp/gmp_4.3.1.bb, do_configure)
NOTE: Running task 697 of 2974 (ID: 1071, /home/babachomu/bm750/openembedded/recipes/python/python_2.6.7.bb, do_populate_staging)
NOTE: Legacy staging mode for /home/babachomu/bm750/openembedded/recipes/python/python_2.6.7.bb
NOTE: Running task 699 of 2974 (ID: 1932, /home/babachomu/bm750/openembedded/recipes/wvstreams/wvstreams_4.6.bb, do_configure)
NOTE: Running task 700 of 2974 (ID: 1933, /home/babachomu/bm750/openembedded/recipes/wvstreams/wvstreams_4.6.bb, do_compile)
NOTE: Running task 701 of 2974 (ID: 2005, /home/babachomu/bm750/openembedded/recipes/gmp/gmp_4.3.1.bb, do_compile)
NOTE: Running task 702 of 2974 (ID: 2006, /home/babachomu/bm750/openembedded/recipes/gmp/gmp_4.3.1.bb, do_install)
NOTE: Running task 704 of 2974 (ID: 476, /home/babachomu/bm750/openembedded/recipes/util-linux-ng/util-linux-ng_2.18.bb, do_fetch)
NOTE: fetch http://kernel.org/pub/linux/utils/util-linux-ng/v2.18/util-linux-ng-2.18.tar.bz2
--2013-01-16 12:46:21-- http://kernel.org/pub/linux/utils/util-linux-ng/v2.18/util-linux-ng-2.18.tar.bz2
Resolving kernel.org (kernel.org)... 149.20.4.69, 149.20.20.133
Connecting to kernel.org (kernel.org)|149.20.4.69|:80... connected.
HTTP request sent, awaiting response... 404 Not Found
2013-01-16 12:46:22 ERROR 404: Not Found.
NOTE: fetch http://mirrors.openembedded.org//util-linux-ng-2.18.tar.bz2
--2013-01-16 12:46:22-- http://mirrors.openembedded.org//util-linux-ng-2.18.tar.bz2
Resolving mirrors.openembedded.org (mirrors.openembedded.org)... 82.197.159.157
Connecting to mirrors.openembedded.org (mirrors.openembedded.org)|82.197.159.157|:80... failed: No route to host.
NOTE: fetch http://sources.openembedded.org//util-linux-ng-2.18.tar.bz2
--2013-01-16 12:46:25-- http://sources.openembedded.org//util-linux-ng-2.18.tar.bz2
Resolving sources.openembedded.org (sources.openembedded.org)... 140.211.169.152
Connecting to sources.openembedded.org (sources.openembedded.org)|140.211.169.152|:80... connected.
2013-01-16 12:46:26 ERROR 404: Not Found.
NOTE: Task failed: Fetch failed: http://kernel.org/pub/linux/utils/util-linux-ng/v2.18/util-linux-ng-2.18.tar.bz2;name=archive
ERROR: TaskFailed event exception, aborting
ERROR: Build of /home/babachomu/bm750/openembedded/recipes/util-linux-ng/util-linux-ng_2.18.bb do_fetch failed
ERROR: Task 476 (/home/babachomu/bm750/openembedded/recipes/util-linux-ng/util-linux-ng_2.18.bb, do_fetch) failed
NOTE: Waiting for 1 active tasks to finish
NOTE: 1: /home/babachomu/bm750/openembedded/recipes/wvstreams/wvstreams_4.6.bb, do_compile (13600)
NOTE: Tasks Summary: Attempted 702 tasks of which 553 didn't need to be rerun and 1 failed.
ERROR: '/home/babachomu/bm750/openembedded/recipes/util-linux-ng/util-linux-ng_2.18.bb' failed
make: *** [image] Error 1
ich komme auch nicht mehr klar was muss ich machen kann es auch sein das ich SDK falsch installiert habe? wie muss ich richtig installieren? Danke voraus
Put the attached file into your sources/ folder and remove the util-linux-ng-2.18.tar.bz2.lock file and restart compile process.
habe ich source ordner kopiert und til-linux-ng-2.18.tar.bz2.lock file gelöscht neu gestartet aber wieder das gleiche fehler.
babachomu@babachomu-P5W-DH-Deluxe:~$ make -f Makefile-vuplus-1.6k image MACHINE=bm750
cd bb && git pull origin 1.8-dream
Von http://code.vuplus.com/git/bitbake
* branch 1.8-dream -> FETCH_HEAD
Already up-to-date.
cd /home/babachomu/bm750/openembedded && git pull origin vuplus-1.6k
Von http://code.vuplus.com/git/openembedded
* branch vuplus-1.6k -> FETCH_HEAD
Already up-to-date.
cd /home/babachomu/bm750/build; . ./env.source; bitbake -f vuplus-image
NOTE: Psyco JIT Compiler (http://psyco.sf.net) not available. Install it to increase performance.
NOTE: Handling BitBake files: \ (8295/8295) [100 %]
NOTE: Parsing finished. 7648 cached, 321 parsed, 326 skipped, 2 masked.
NOTE: Resolving any missing task queue dependencies
NOTE: Preparing runqueue
NOTE: Executing runqueue
NOTE: Running task 705 of 2974 (ID: 476, /home/babachomu/bm750/openembedded/recipes/util-linux-ng/util-linux-ng_2.18.bb, do_fetch)
NOTE: Running task 728 of 2974 (ID: 1870, /home/babachomu/bm750/openembedded/recipes/gstreamer/gst-plugins-bad_0.10.22.bb, do_unpack)
NOTE: Unpacking ../../sources/gst-plugins-bad-0.10.22.tar.bz2 to tmp/work/mipsel-oe-linux/gst-plugins-bad-0.10.22-r0.2/
--2013-01-16 22:34:44-- http://kernel.org/pub/linux/utils/util-linux-ng/v2.18/util-linux-ng-2.18.tar.bz2
Resolving kernel.org (kernel.org)... 149.20.20.133, 149.20.4.69
Connecting to kernel.org (kernel.org)|149.20.20.133|:80... connected.
2013-01-16 22:34:45 ERROR 404: Not Found.
--2013-01-16 22:34:45-- http://mirrors.openembedded.org//util-linux-ng-2.18.tar.bz2
--2013-01-16 22:34:48-- http://sources.openembedded.org//util-linux-ng-2.18.tar.bz2
Connecting to sources.openembedded.org (sources.openembedded.org)|140.211.169.152|:80... NOTE: Running task 729 of 2974 (ID: 1856, /home/babachomu/bm750/openembedded/recipes/gstreamer/gst-plugin-dvbmediasink.bb, do_setscene)
connected.
2013-01-16 22:34:49 ERROR 404: Not Found.
NOTE: 1: /home/babachomu/bm750/openembedded/recipes/gstreamer/gst-plugin-dvbmediasink.bb, do_setscene (2346)
NOTE: Tasks Summary: Attempted 727 tasks of which 726 didn't need to be rerun and 1 failed.
make: *** [image] Fehler 1
Noch ein scritt weiter aber jetz hängt er wieder waum mach er soviel probleme.
Already up-to-date.
Already up-to-date.
NOTE: Handling BitBake files: - (8294/8294) [100 %]
NOTE: Parsing finished. 7647 cached, 321 parsed, 326 skipped, 2 masked.
NOTE: Running task 755 of 2974 (ID: 1953, /home/babachomu/bm750/openembedded/recipes/usbutils/usbmodeswitch-data_20120120.bb, do_fetch)
NOTE: Running task 794 of 2974 (ID: 1714, /home/babachomu/bm750/openembedded/recipes/jpeg/jpeg_6b.bb, do_unpack)
NOTE: Unpacking ../../sources/jpegsrc.v6b.tar.gz to tmp/work/mipsel-oe-linux/jpeg-6b-r8/
NOTE: fetch http://www.draisberghof.de/usb_modeswitch/usb-modeswitch-data-20120120.tar.bz2
--2013-01-17 13:59:58-- http://www.draisberghof.de/usb_modeswitch/usb-modeswitch-data-20120120.tar.bz2
Resolving www.draisberghof.de (www.draisberghof.de)... NOTE: Running task 795 of 2974 (ID: 2183, /home/babachomu/bm750/openembedded/recipes/python/python-setuptools-native_0.6c9.bb, do_patch)
213.252.188.4
Connecting to www.draisberghof.de (www.draisberghof.de)|213.252.188.4|:80... NOTE: Applying patch 'fix-log-usage.patch' (../openembedded/recipes/python/python-setuptools/fix-log-usage.patch)
connected.
2013-01-17 14:00:00 ERROR 404: Not Found.
NOTE: fetch http://mirrors.openembedded.org//usb-modeswitch-data-20120120.tar.bz2
--2013-01-17 14:00:00-- http://mirrors.openembedded.org//usb-modeswitch-data-20120120.tar.bz2
Resolving mirrors.openembedded.org (mirrors.openembedded.org)... NOTE: Running task 796 of 2974 (ID: 2184, /home/babachomu/bm750/openembedded/recipes/python/python-setuptools-native_0.6c9.bb, do_configure)
82.197.159.157
Connecting to mirrors.openembedded.org (mirrors.openembedded.org)|82.197.159.157|:80... NOTE: Running task 797 of 2974 (ID: 2185, /home/babachomu/bm750/openembedded/recipes/python/python-setuptools-native_0.6c9.bb, do_compile)
NOTE: Running task 798 of 2974 (ID: 2186, /home/babachomu/bm750/openembedded/recipes/python/python-setuptools-native_0.6c9.bb, do_install)
NOTE: fetch http://sources.openembedded.org//usb-modeswitch-data-20120120.tar.bz2
--2013-01-17 14:00:03-- http://sources.openembedded.org//usb-modeswitch-data-20120120.tar.bz2
2013-01-17 14:00:04 ERROR 404: Not Found.
NOTE: Task failed: Fetch failed: http://www.draisberghof.de/usb_modeswitch/usb-modeswitch-data-20120120.tar.bz2
ERROR: Build of /home/babachomu/bm750/openembedded/recipes/usbutils/usbmodeswitch-data_20120120.bb do_fetch failed
NOTE: Running task 799 of 2974 (ID: 1695, /home/babachomu/bm750/openembedded/recipes/dreambox/dreambox-dvbincludes.bb, do_populate_staging)
ERROR: Task 1953 (/home/babachomu/bm750/openembedded/recipes/usbutils/usbmodeswitch-data_20120120.bb, do_fetch) failed
NOTE: 1: /home/babachomu/bm750/openembedded/recipes/dreambox/dreambox-dvbincludes.bb, do_populate_staging (21284)
NOTE: Tasks Summary: Attempted 797 tasks of which 792 didn't need to be rerun and 1 failed.
ERROR: '/home/babachomu/bm750/openembedded/recipes/usbutils/usbmodeswitch-data_20120120.bb' failed
jetz hänge ich wieder wie kann ich die fehlern orrigieren?
CC config.c
CC notify.c
CC bss.c
CC eap_register.c
CC ../src/utils/common.c
CC ../src/utils/wpa_debug.c
CC ../src/utils/wpabuf.c
CC ../src/utils/os_unix.c
CC ../src/utils/eloop.c
CC config_file.c
CC ../src/rsn_supp/wpa.c
CC ../src/rsn_supp/preauth.c
CC ../src/rsn_supp/pmksa_cache.c
CC ../src/rsn_supp/peerkey.c
CC ../src/rsn_supp/wpa_ie.c
CC ../src/common/wpa_common.c
CC ../src/eap_peer/eap_tls.c
CC ../src/eap_peer/eap_peap.c
CC ../src/eap_common/eap_peap_common.c
CC ../src/eap_peer/eap_ttls.c
CC ../src/eap_peer/eap_md5.c
CC ../src/eap_peer/eap_mschapv2.c
CC ../src/eap_peer/mschapv2.c
CC ../src/eap_peer/eap_gtc.c
CC ../src/eap_peer/eap_otp.c
CC ../src/eap_peer/eap_leap.c
CC ../src/eapol_supp/eapol_supp_sm.c
CC ../src/eap_peer/eap.c
CC ../src/eap_peer/eap_methods.c
CC ../src/crypto/ms_funcs.c
CC ../src/eap_common/chap.c
CC ../src/eap_peer/eap_tls_common.c ../src/crypto/tls_gnutls.c: In function 'tls_connection_set_params':
../src/crypto/tls_gnutls.c:603: error: 'GNUTLS_VERIFY_DISABLE_TIME_CHECKS' undeclared (first use in this function)
../src/crypto/tls_gnutls.c:603: error: (Each undeclared identifier is reported only once ../src/crypto/tls_gnutls.c:603: error: for each function it appears in.)
../src/crypto/tls_gnutls.c: In function 'tls_global_set_params':
../src/crypto/tls_gnutls.c:735: error: 'GNUTLS_VERIFY_DISABLE_TIME_CHECKS' undeclared (first use in this function)
../src/crypto/tls_gnutls.c: In function 'tls_connection_verify_peer':
../src/crypto/tls_gnutls.c:891: error: 'GNUTLS_CERT_NOT_ACTIVATED' undeclared (first use in this function)
../src/crypto/tls_gnutls.c:896: error: 'GNUTLS_CERT_EXPIRED' undeclared (first use in this function) make: *** [../src/crypto/tls_gnutls.o] Error 1
From http://code.vuplus.com/git/bitbake
Already up-to-date.
From http://code.vuplus.com/git/openembedded
Already up-to-date.
NOTE: Psyco JIT Compiler (Psyco - Home Page) not available. Install it to increase performance.
NOTE: Handling BitBake files: / (8293/8293) [100 %]
NOTE: Parsing finished. 7646 cached, 321 parsed, 326 skipped, 2 masked.
NOTE: Running task 1422 of 2974 (ID: 2240, /home/babachomu/bm750/openembedded/recipes/wireless-tools/wireless-tools_29.bb, do_setscene)
NOTE: Running task 1758 of 2974 (ID: 2257, /home/babachomu/bm750/openembedded/recipes/wpa-supplicant/wpa-supplicant_0.7.3.bb, do_compile)
ERROR: function do_compile failed
ERROR: see log in /home/babachomu/bm750/build/tmp/work/mipsel-oe-linux/wpa-supplicant-0.7.3-r7.1/temp/log.do_compile.26640
NOTE: Task failed: /home/babachomu/bm750/build/tmp/work/mipsel-oe-linux/wpa-supplicant-0.7.3-r7.1/temp/log.do_compile.26640
ERROR: Build of /home/babachomu/bm750/openembedded/recipes/wpa-supplicant/wpa-supplicant_0.7.3.bb do_compile failed
ERROR: Task 2257 (/home/babachomu/bm750/openembedded/recipes/wpa-supplicant/wpa-supplicant_0.7.3.bb, do_compile) failed
NOTE: 1: /home/babachomu/bm750/openembedded/recipes/wireless-tools/wireless-tools_29.bb, do_setscene (26595)
NOTE: Tasks Summary: Attempted 1756 tasks of which 1756 didn't need to be rerun and 1 failed.
ERROR: '/home/babachomu/bm750/openembedded/recipes/wpa-supplicant/wpa-supplicant_0.7.3.bb' failed
Have fun Thank all.
NOTE: Running task 2967 of 2974 (ID: 36, /home/chomu/bm750/openembedded/recipes/quilt/quilt-native_0.48.bb, do_package_write)
NOTE: Running task 2970 of 2974 (ID: 15, /home/chomu/bm750/openembedded/recipes/images/vuplus-image.bb, do_package_update_index_ipk)
NOTE: Running task 2971 of 2974 (ID: 38, /home/chomu/bm750/openembedded/recipes/quilt/quilt-native_0.48.bb, do_package_stage)
NOTE: Running task 2972 of 2974 (ID: 12, /home/chomu/bm750/openembedded/recipes/images/vuplus-image.bb, do_package_stage_all)
NOTE: Running task 2973 of 2974 (ID: 9, /home/chomu/bm750/openembedded/recipes/images/vuplus-image.bb, do_rootfs)
NOTE: Running task 2974 of 2974 (ID: 0, /home/chomu/bm750/openembedded/recipes/images/vuplus-image.bb, do_build)
NOTE: Tasks Summary: Attempted 2974 tasks of which 1612 didn't need to be rerun and 0 failed.
DvbApp2: experimental-git2
Machine: Vuplus bm750
Date: 20130120
Issuer: Vuplus
Link: http://archive.vuplus.com/openembedd...s/feeds/stable
MD5: cd2d21866bf11bbc1c260599fbba20a6[/code]
