Fade effect
safari815
I run vu+duo BH 2.1.2 and was wondering if it is possible to get the fade effect in the OSD. I tried to install BH 2.1.3 and 2.1.4 which are fade effect, but get the image crash. Thanks.
bogdanm
Moderator
This efeckt was add to 2.1.3 i think and no will be work on old images.
Why you have crashes on new version image?
You try setup all from begined from scratch?
safari815
Thank you for reply.
I'll have crashes when I watch any movie using advanced movie selection or enhanced movie center and then goes back tlll channels. Duo hangs directly and reset. Then I get no sound and I must reboot it. Then freezes again and I must press the back button to start a duo again. With BH 2.1.2 works perfectly, but 2.1.3 and 2.1.4 major problems. I removed the AMS and EMC, but it happens again when I change channels.
safari815
Thanks for your reply.
I have already tried with HD Glass skin, but hangs frequently. I tried to run vu duo Backup 2.1.4 from memorist with all installed components. The same problem. Greenscreen. I have gone back to 2.1.2. Works perfect. Both the regular channels and IPTV channels and AMS and EMC. 2.1.4 is prettier. But design or functionality. I choose the second.
