Alejandro Alvarez
Hello,
I've recently bought an UNO4KSE, installed BH and plugged to my old antenna that I havent used since some years ago that was on HS 30 and a tecnician positioned to Astra 19.2.
The signal is good (about 90% on most of the channels), however it randomly drops to 0 and does not automatically recovers.
The main sympton is, I am watching some channel without any issue, then suddenly the image starts pixelating really hard, the signal meters bounces from 0 to max value and eventually it gets completely lost and at this point the only way to recover signal is unplugging the antenna cable from the UNO4K and plugging again. Reset does not help at all.
After plugging and for what I've seen its really random if the signal is going to be lost again in few seconds or it will remain ok for hours or even days.
This does not happen all the time, I would say in a month it has happened 5-6 times.
I've checked the messages and dmesg log of the device and I see lots of "FE tune" messages, if that can help diagnose.
What do you think? Is it a bad unit or maybe its the lbn that needs replacement?
