Firefox send to Vu+
caka
I find something that maybe could be interesting "Send to VuPlusReceiver" Firefox plugin.
As it is not allowed to put external links on forum use Google search to check what is and how it works!
angelofsky1980
BlackHole Driver Specialist
You can put links behind code tag :)
x-xxxA
File attached below. Put the extracted file on your desktop, then right click and open it with Firefox. Install in Firefox. Restart Firefox. Go to Tools - Add-ons and Extensions
There should be a plugin Send to VuPlusReceiver. Choose Options of this plugin and put VuPlusReceiver IP. Exit. That's all.
When you open YouTube on Firefox and select a clip, on the right hand side there will be a Send to VuPlayer and when you click on it, the clip will be shown on TV instantly. If you have to select another clip from the other selections that your search found and that are on the right hand side of the page, all you have to do is right click on it and from the drop menu select Send to VuPlus.
  • send-to-vuplus@jetpack_1_0_0_1.rar
