Freezes randomly since update to 1.7.2 and duo_cfe_3_0_usb.zip)
EvO ok i understand this but if it help dose not matter what is running on the box to make my orig sky card run it will freeze on all versions
thanks anyways guess i will stay at 1.6.6 and just keep trying updates as they come out
thanks all again
Cozmo
The fact that it only happens with that card, kind of proves that, that is the problem i'm afraid.
I assume it is the same in both slots, and even if you remove the other card
have not tried other slot as guessed it would be the same i will have a play when i get more time as going to work soon but worth a try. Just strange that it works fine on same settings on 1.6.6 and lower never had any problem till 1.6.7 came out oh and one more thing its only when the cards or card is running eg. they can be in the slots but not active and the box will run bbc-hd fine no freeze
anyways as i said thanks for you help guess its just one of them thing at lest i can still use a BH image so i happy
thanks again
Cozmo
i have the same problem with my ultimo, the problems is thats this is happening from one day to other without changing anything in my box. i wakeup one day and the problem begin, now the story is that is only happens in a few members and nobody knows excatly with is the cause of the problem. we dont have any crash reports nothing to see wheer is the problem, so is even more worst. :(
In this thread we talk about Duo boxes and not Ultimo.
I think the problem you have is related to something added to Image. Retry with a clean image first ...
just a quick update to my problem with freezing EvO hit that nail on the head it was not my sky card but the other card in the box infact from the diff its made when i take it out on any image i think the card must have a fault but stopped freezing straight away 100% on all black hole images very very happy now thanks for all the help :)))
No probs, good to hear it's all working as it should for you now.
OK GUYS
PROBLEM SOLVED!!!
PROBLEM SOLVED!!!
PROBLEM SOLVED!!!
(uptime 18 days..., no a single freeze)
Enjoy the life ALWAYS - we live only once :).
Content was edited!
You have been warnned!
No emu discussion!
Read the roles!
OK GUYS
PROBLEM SOLVED!!!
PROBLEM SOLVED!!!
PROBLEM SOLVED!!!
Content was edited!
No emu discussion!
Read the roles!
ok, anyone who wants to get this solution, plz, write to my inbox since the solution related to not allowed content by the forum rules.
Umm, I've sent you a request to your inbox as you suggested. You suppose you could find time to reply some day?
Could you please post a case test to replicate this problem?
My Vu+ Duo freeze again.
Image: BH 1.7.4.0
Settings: Setup --> System --> Fan control:
Fan basic action : Off
Use fan timer : Yes
Fan on duration time : 015
Fan off duration time : 050
Blue panel --> Extra settings --> Swap File Settings:
Swap place : USB
Swap Size : 256 M
Status : Active
My box freeze is a 4 days or so.
Box freeze only is standby mode.
Next freeze randomly inside of two days. (Only box in standby mode)
With BH 1.6.6 image and equal settings box no freeze.
Sorry for my bad english.
T0: BH Team
Can I get the sources of BH images? I would like to participate to develop BH image especially to try cleaning this freezing bug if possible . Let's say I do have a very very extended knowledge in C++.
I testing BH 1.7.4.0 image too.
When settings:
Use fan timer : Yes
and swap file disabled, box freeze after 3 days. (In standby)
When settings:
Fan basic action : On
and swap settings:
Swap place : USB
Swap Size : 256 M
Status : Active
box NO FREEZE!! (Fan always on. :-( )
The Bug in Standby mode Fan control.
When settings:
Use fan timer : Yes
When settings:
and swap settings:
Swap place : USB
Swap Size : 256 M
Status : Active
I think the problem not exists.
If the box hang when the fan is OFF ... you can have temperature problem into your box and it stop working to avoid other big problems.
Into my boxes I've enabled the fan to be ON into standby to maintain a good temperature and I haven't hangs or similar issues.
Yes!
"the problem not exists." with BH 1.6.6.
All image with kernel 3.1.1 the problem exists.
I've used the 3.1.1 kernel from 1.6.7 images and none of my boxes has the problems you have explained with or without fan ON.
Are you sure your box is genuine?
"Are you sure your box is genuine?"
Yes!
I checked with BH image. I buy 2010.03.
SN: MA001301298
