Sturlus stugi
I have a vu+ solo and latest BH image installed. I have instalt USB as universe, I have a 32 GB USB connected.
In this particular logfile i got GSOD when trying to enter COOLMANTVGUIDE-SETUP from plugins-meny in BH. But i also get this error other times. also when trying to switch universes. I see that the error-report points to a python folder in usr/enigma2/python.. when I FTP to my box i can't see that folder. Is something missing?
Please help me out
Please help me out
<?xml version="1.0" encoding="utf-8"?>
<opendreambox>
<enigma2>
<crashdate>Mon Feb 25 14:56:37 2013</crashdate>
<compiledate>Feb 17 2013</compiledate>
<contactemail>#######################################</contactemail>
<skin>skin.xml</skin>
<sourcedate>2013-02-17</sourcedate>
<branch>vuplus_experimental</branch>
<rev>exp-2010.12-1025-ga0a1fbc</rev>
<version>3.0.0</version>
</enigma2>
<image>
<dreamboxmodel>dm500hd</dreamboxmodel>
<kernelcmdline>bmem=144M ubi.mtd=0 root=ubi0:rootfs rootfstype=ubifs rw rootflags=sync</kernelcmdline>
<imageversion>
<![CDATA[
version=1000201302161754
</imageversion>
<imageissue>
<![CDATA[
BlackHole 2.0.0 %h
</imageissue>
</image>
<software>
<enigma2software>
<!-- Cannot allocate memory -->
</enigma2software>
<dreamboxsoftware>
</dreamboxsoftware>
<gstreamersoftware>
</gstreamersoftware>
</software>
<crashlogs>
<enigma2crashlog>
<![CDATA[
po in keymap?
[eDVBCAService] send 65 bytes
9f 80 32 3d 03 04 14 11 00 19 01 81 08 0e 07 00 00 00 46 00 46 82 02 01 00 84 02 01 07 09 04 0b 00 e0 66 1b 02 02 00 00 04 02 88 00 00 06 02 89 00 00 06 02 40 00 00 06 02 5c 00 00 06 02 5d 00 00
action -> InfobarShowHideActions toggleShow
action -> CoolTVGuideActions CoolOK
unknown action CoolTVGuideActions/CoolOK! typo in keymap?
[EPGC] start cleanloop
[EPGC] stop cleanloop
[EPGC] 3547529 bytes for cache used
action -> CoolTVGuideActions CoolCancel
unknown action CoolTVGuideActions/CoolCancel! typo in keymap?
action -> InfobarShowHideActions hide
action -> GlobalActions volumeMute
setValue 0
action -> CoolTVGuideActions CoolRed
das war wohl nix
Looking for embedded skin
allocating new converter!
reused converter!
[Picload] setPara max-X=50 max-Y=30 aspect_ratio=1.000000 cache=0 resize=1 bg=#00000000
[Picload] setPara max-X=1 max-Y=1 aspect_ratio=1.000000 cache=0 resize=1 bg=#00000000
[Picload] decode picture... /usr/lib/enigma2/python/Plugins/Extensions/CoolTVGuide/Cool3D/dummy.png
ERROR reading PES (fd=40) - Value too large for defined data type
ERROR reading PES (fd=43) - Value too large for defined data type
action -> EPGSelectActions yellow
unknown action EPGSelectActions/yellow! typo in keymap?
action -> CoolTVGuideActions CoolYellow
reused converter!
reused converter!
no ancillary data in audio stream... abort radiotext pes parser
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
action -> EPGSelectActions info
unknown action EPGSelectActions/info! typo in keymap?
action -> CoolTVGuideActions CoolInfo
reused converter!
reused converter!
reused converter!
reused converter!
action -> EPGSelectActions input_date_time
unknown action EPGSelectActions/input_date_time! typo in keymap?
action -> CoolTVGuideActions CoolMenu
Screen <class 'Plugins.Extensions.CoolTVGuide.plugin.CoolTVGuideSetup'>((), {}): <type 'exceptions.OSError'>
File "/usr/lib/enigma2/python/mytest.py", line 239, in create
return screen(self, *arguments, **kwargs)
File "/usr/lib/enigma2/python/Plugins/Extensions/CoolTVGuide/plugin.py", line 1850, in __init__
File "/usr/lib/enigma2/python/Plugins/Extensions/CoolTVGuide/plugin.py", line 1919, in ymrjqy
OSError: [Errno 12] Cannot allocate memory
File "/usr/lib/enigma2/python/Components/ActionMap.py", line 46, in action
res = self.actions[action]()
File "/usr/lib/enigma2/python/Plugins/Extensions/CoolTVGuide/plugin.py", line 1580, in mtjqyr
File "/usr/lib/enigma2/python/mytest.py", line 302, in openWithCallback
dlg = self.open(screen, *arguments, **kwargs)
File "/usr/lib/enigma2/python/mytest.py", line 313, in open
dlg.isTmp = True
AttributeError: 'NoneType' object has no attribute 'isTmp'
(PyObject_CallObject(<bound method ActionMap.action of <Components.ActionMap.ActionMap instance at 0x28b5f08>>,('CoolTVGuideActions', 'CoolMenu')) failed)
</enigma2crashlog>
<pythonMD5sum>
</pythonMD5sum>
</crashlogs>
</opendreambox>
