I know it's an old thread here, but,
I'm getting same error when playing some files or streaming from youtube, any solution for that?
thanks
Video
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : 2
Format settings, QPel : Yes
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Muxing mode : Packed bitstream
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 21mn 18s
Bit rate : 609 Kbps
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.079
Stream size : 92.9 MiB (82%)
Writing library : XviD 1.2.1 (UTC 2008-12-04)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 21mn 18s
Bit rate mode : Constant
Bit rate : 128 Kbps
General
Unique ID : 240164838484078050891376944494890926315 (0xB4AE10BE388EA2F8887622B5A04F40EB)
Complete name : Format : Matroska
Format version : Version 2
File size : 338 MiB
Duration : 24mn 31s
Overall bit rate : 1 927 Kbps
Encoded date : UTC 2010-09-03 23:47:21
Writing application : mkvmerge v3.3.0 ('Language') built on Mar 24 2010 14:59:24
Writing library : libebml v0.8.0 + libmatroska v0.9.0
Attachment : Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes
Video
Format : VC-1
Codec ID : WMV3
Codec ID/Info : Windows Media Video 9
Codec ID/Hint : WMV3
Duration : 24mn 31s
Bit rate : 1 633 Kbps
Width : 640 pixels
Height : 480 pixels
Frame rate : 24.950 fps
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.213
Stream size : 286 MiB (85%)
Title : AlSadiq
Language : Arabic
Default : Yes
Forced : Yes
Audio #1
Format : MPEG Audio
Codec ID : A_MPEG/L3
Codec ID/Hint : MP3
Duration : 24mn 31s
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Stream size : 22.4 MiB (7%)
Title : AlSadiq
Writing library : LAME3.98r
Encoding settings : -m s -V 4 -q 3 -lowpass 17 -b 128
Language : Arabic
Default : Yes
Forced : Yes
Audio #2
Format : MPEG Audio
Codec ID/Hint : MP3
Duration : 24mn 31s
Bit rate : 128 Kbps
Title : AlSadiq
Language : Japanese
Default : No
Forced : No
Text
Format : ASS
Codec ID : S_TEXT/ASS
Codec ID/Info : Advanced Sub Station Alpha
Compression mode : Lossless
Title : AlSadiq
Language : Arabic
Default : Yes
Forced : Yes
