Internal SATA HDD problem Ultimo
thfccambs
For some reason my hard drive has gone as in not showing at all on my v+ultimo?
Was fine today as ive been watching some recordings on it.
When i go into settings it says no HDD showing?
Any ideas how to get it back showing, hopefully without losing everything.
Image im using is Blackhole at the moment.
Thanks
try hard reset first and then answer the below:
what version of BH do you have?
what kind of hdd? internal? external? what size? files format? how have you mounted it?
what have you installed recently?
there is plenty of questions we want to ask, but if you can't post more info we can't help you.
Shiro
BH-C
It seems an hardware issue because the hdd is no more detected.
try to open the box, disconnect and reconnect hdd cables.
thfccambs
Blackhole 1.7.9 build dec 6
tried hard reset
Internal drive
1.0 TB 2,5 drive
Nothing been installed recently
Was working fine until today
