There are videos, on youtube, but it's pretty straight forward, once you remove the top cover, off your receiver.
Ensure you've completely disconnected it, from the mains, before opening the receiver:
This one is for installing a 2.5" Hard Drive, but the 3.5" is similar.
Or do you mean mounting it using the menu options, in Black Hole, or Open Black Hole?
