Help needed please
daztfs
  1. Hi Guys, I tired to re flash my box with 1.7.4 and I read that I needed to update the boot first so I used this one/vuplus/solo/cfe_cfe_auto.bin) which I was told i needed to update before the update would go on, Now my box boots the TV shows the supported mode then normally the Black hole screen now comes up but the TV just goes to a dark black screen, If i leave the box switched on it seems to go through booting process on its own as I keep seeing TV say check cable then it comes up 720 so I know box is talking to it, IT does not matter which image i now use I can not get anything back on box.
daztfs
I am sure the box is taking the files as the Orange light is on and the USB flashes then the USB stops flashing and box goes green, I am sure it's something to do with boot loader as it seems it's not booting. I did make a mistake though first time aound I didn't format in fat 32 when I first tried the boot loader.
