bouncerdove
Hi all Here is my preent setup.
VU+ Ultimo
Tuner A standared unit supplied with unit with loop through
Tuner B standard unit supplied with unit with loop through
Tuner C & D dual tuner unit with no loop through.
1.5m dish connected to A set to usals
tuner B set to second cable of motorised system.
This has worked perfect.
Now I have added a dual tuner connected to a seperate dish fixed at 28.2 with dual outputs connected to Tuner C & D. All dishes etc are aligned perfectly
Could someone please advise what the best settings for the tuners should be to get the most from my system. I have searched the forum but the answer only seem to talk about 3 tuners at most and don't mention priotiy in the settings and what it does.
Many thanks in advance
Regards bouncerdove
VU+ Ultimo
Regards bouncerdove
