I don't see it in the drivers list. Where is it?you can try driver dib0700
a19a
If it's not supported is not a big problem because the BH Panel doesen't load at box startup the driver if it's not useful.ok found...it is WinTV Nova...but it doesn't work.
Now, how do I REMOVE this driver? thanks!
a19a
cat /proc/bus/usb/devices
Please post this commando output to help me discover which driver you need, it's a telnet command:Code:cat /proc/bus/usb/devices
You have a 2nd version of EyeTV DTT Dlx.cat /proc/bus/usb/devices gives:
T: Bus=01 Lev=01 Prnt=01 Port=01 Cnt=01 Dev#= 3 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=ff(vend.) Sub=ff Prot=ff MxPS=64 #Cfgs= 1
P: Vendor=0fd9 ProdID=002c Rev= 1.00
S: Manufacturer=Elgato
S: Product=EyeTV DTT Dlx
S: SerialNumber=xxxxxxxxxxxxxxx
C:* #Ifs= 1 Cfg#= 1 Atr=80 MxPwr=300mA
I: If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
E: Ad=01(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=82(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=83(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
Officially your device is not supported by LinuxTV (and Linux world too) but I have read some posts on the web who suggest to modify some lines into one driver.
I will try and inform you when the new driver is ready to test.
Yes. I need to test the procedure you are linked.@angelofsky1980
are you speaking about this procedure?
Re: ELGATO EYETV DTT, chiavetta usb per digitale terrestre
thanks,
a19a
