how can i delete some channels?
aziz100
some channels like adult channels are bothering me how can i delete them?
is there any way to lock satellite from the reciever?
i,m using (vu+duo )
a911
The BH Lover
i,m using (vu+duo )
Use Parental Luck!
Menu>setup>>Parental Control!
And then @Channel list, choose the channel you want to block!
press
Menu>add to Parental Protection!
It works fine!
Have Fun w/BH
Basil
By this way, you can delete the channels only from bouquet, not from channels list.
Pls what is the difference b/w bouquet and channels list?
A newbie question,hope u don't mind?
Thanks.
Sent from my GT-I9100 using Tapatalk 2
Mito
Thanks.
I will try to explain it in plain words.
A bouquet is a channels list.
You can create several channels list and assign them several names.
