Have a look here: http://www.vuplus-community.net/board/threads/how-to-setup-your-vu-for-recording-on-usb.5491/is there a guide any where.
using blackhole 1.72 and have no idea how to install external usb hardrive
thanks
Maybe there is a supply issue.Hi.
I use BH 1.7.3 on a Vu+ Duo.
I have a problem with a 2 TB external USB HDD. It dont show up in the device manager. When reboot the disk will spin up, but I cant use it/find it.
I have a internal HDD and a USB-stick conected to the box already.
The USB disk was previously used on my old DM800, and there it behaved normally. It contains 1,5TB of material, and I hope I dont have to format it...
I beleave it is set up with ext4 file system.
Does anybody know how I can use it? Some way to manually set it up throug telnet?
I get an error message after step 3: mount: mounting /dev/sdb on /media/hdd2 failed: device or resource busy
Hi.
