How to capture channel service codes with VLC Player
Rytec
Moderator
To capture a single service reference use the following procedure:
1. Install VLC player on your PC
1. Open the webif of your box.
2. Find the channel from which you want the reference
3. Stream this channel to your PC.
4. VLC opens the channel,
5. On VLC click on extra and Media-Information. Here you will find the service reference
6. Then select the code starting with 1:0:.... by keeping the left mouse button pressed and after you selected the line use CTRL-C to copy it to the clipboard.
7. With CTRL-V you can paste this selection where you want and especially in a topic here on this forum
