How to delete all Kodi data and reset default settings?
smed79
Hello,
how to delete all Kodi data and reset default settings?
STB: Vu+ Zero4K
Firmware: Black Hole 3.0.5 K (Build 2018-04-09-master)
Thank you.
If im good remember you mast delete Kodi folder in hdd or usb [ i dont know where you have this folder ].
This folder is " hiden "
It depends what you want to uninstall, you can either uninstall specific source, addons, etc..
Alternatively I once used an add on, that gives you a clean start, and restores Kodi to how it was originally installed, allowing you to start from scratch.
I can't remember which one I used but try an internet search for how to do a fresh start, on VU+, or an Enigma2 receiver.
https://www.youtube.com/watch?v=-zPJMcWltWY
https://www.youtube.com/watch?v=qTVoSfLu-dk
https://www.youtube.com/watch?v=5A4gdtYGKpo
