how to edit keymap.xml
I'm still a beginner in this, thanks for the tips. I found skin that has the same layout as those in the picture. The idea of developers about bouquets is still not clear to me, but I'll learn it.
The idea it's simple: its purpose is to group channels the way you like: by language, by genre, by whatever. Within every bouquet, you can also add "markers" that are just descriptions: for instance: kids, sport, etc.
All the other channels you don't need will always be available but they won't be numbered. Only channels included in any bouquets are numbered.
With OBH you can also jump to the first channel starting with the letter contained in the remote key AFTER having shown with UP/DOWN the channels in the current bouquet (for example, pressing the "2" key on the remote, as it contains "2abc", the first time you press it you'll select the first channel beginning by "a"; then, if you press again it, it'll go to the first channel beginning by "b", and so on. The same with the other key-s.
So there are many ways to browse channels. But, as I said, bouquets are not compulsory. You could have only one bouquet and, within it, channels separated by markers.
If you are new to VU+, I suggest to gain some experience and become more acquainted with other main aspects, before focusing on bouquets and channels.
Ok. OBH means Open Black Hole? What is the relationship between BH and OBH?
Yes, OBH is OpenBlackHole.
They are two different projects. Impossible to synthesize in few words.
Try for ad adequate time and it'll be easier to judge it.
Both images are supported in this forum.
Well, after several tests I manage to use the k_e_y_s "channel up + down" only for zapUP and zapDown.
If if press the left key (or the right key), the behavior is like when I press the the up or down on the same circle joystick. (it activate the list of the channels).
On the same XML that I upload, I have remove the yellow button.
Very often I press by mistake this, and the timeshift was activated to play with my nerves.
The location for this file is
USR => Share => Enigma2
If you unzip and put this xml file there, everything I describe before, will be solved.
There is a bug on that file, no timeshift is working properly.
The following attachment is correct.
Tested on BH 3.09 (Vu Duo 4K)
