Can someone show us how to flash this new receiver of vuplus duo 2 and gives some toutorial?Thanks
Format a pen drive (better if is 1 or 2 Gb) in Fat 32.
Download Bh 2.0.4 and unzip.
The file unzipped is: vuplus\duo2\5 files.
Copy in the pen drive: vuplus\duo2\5 files.
With a decoder turned off from the rear open the frontal flap that hides the Usb port and power button.
Insert the pen drive in the Usb port.
Turn the unit on from the rear switch.
Follow instructions: when asked push the power button near the Usb port.
When the decoder has ended loading extract the pen drive and the deco will restart with new image.
That's all.
