Need to increase subtitle size in default skin. I find it too small. What should I do ?
chulbul BH Lover Sep 12, 2013 #1 Need to increase subtitle size in default skin. I find it too small. What should I do ?
YipMan Vu+ User Sep 13, 2013 #3 look here : http://www.vuplus-community.net/boa...difying-ttx-subtitle-position-and-size.12131/
YipMan Vu+ User Sep 13, 2013 #5 chulbul said: I CANT GET IT TO WORK USING DEFAULT SKIN Click to expand... Yes I know it is difficult to change the skin.xml, py and pyo files comes into play
