The problem that i note is that BH can't detect more than one audio channel: if iptv channel have two or more audio channels, then there is no sound. Is this can be fixed.
XMAS SPAM.
But the reindeer did not take away these spammers ?
HI Guys,
I've got a similar problem. I have bought a good M3U Stream IPTV and it plays perfect on the PC but when I load it to the VU+Duo2 via E-Channelizer, the bouquet loads fine and everything seems OK but I get nothing except a blank screen when I select a channel. There is a dialogue box sometimes saying 'no data on transponder' and I have had occasional success in getting some free IPTV channels working in the past but this has me confused
Regards
Fiachna
Everything related to IPTV in Black Hole image is in the hands from VU + Coders.
Maybe you can send a bug report.
Hi. I've downloaded the m3u8 file from Openwebif. Im trying to see it in my nvidia shield. I just doesn't load the channel no matter what software I use. I can't even use it in the smartphone with the regular enigma2 apps... But... that same m3u8 files works perfectly in my pc with VLC.
Also, i was able to use the streaming using kodi with the enigma2 pvr client. I want to use it with tivimate IPTV app in android tv, but, no luck.
I guess it's probably something how the m3u8 file is created... I have no idea why even the enigma2 players dont work in the smartphone
I will test this tivimate app with my m3u8 !!
