when I do it, I've got message "completed - installed or updated 0 package".Hi, can you explain how to update to BH 2.0.2 Rev A from BH 2.0.2. thanks.
Can u double check what is u version of image first by menu/information/aboutwhen I do it, I've got message "completed - installed or updated 0 package".
Where can I see changelog for BH 2.0.2B?Last version image BH is 2.0.2B
Made update on Blach Hole univers and look whot version you have.
my image version is 2.0.2Can u double check what is u version of image first by menu/information/about
after update, image version still BlackHole 2.0.2 Build: 2013-03-20-masterMade update on Blach Hole univers and look whot version you have.
menu/information/aboutWhere can I see changelog for BH 2.0.2B?
i have duo,ultimo and solo2 not probs updating 2.02 to 2.02b have you got internet connectionmy image version is 2.0.2
yes I've got internet connection, I can update FPGA without problem and do other addons. I don't understand why it doesn't work. you're talking about BH 2.0.2B, I can't find it on the site, I see 2.0.2A. thanks for your replyes.i have duo,ultimo and solo2 not probs updating 2.02 to 2.02b have you got internet connection
Black Hole 2.0.2 rev. B- New: Add a screen @ shutdown/reboot/restart e2 (thx to littlesat e pieterg)yes I've got internet connection, I can update FPGA without problem and do other addons. I don't understand why it doesn't work. you're talking about BH 2.0.2B, I can't find it on the site, I see 2.0.2A. thanks for your replyes.
it didn't work. I updated 2.0.2 A with USB, then I updated online to 2.0.2 B and it worked. Thanks for your help. Thread closed.Black Hole 2.0.2 rev. B- New: Add a screen @ shutdown/reboot/restart e2 (thx to littlesat e pieterg)
- fix framebuffer flicker
- fix bug is osd Dvb-t info
Please Update !!
available for only online update
