how you install and use iptv please help
hamedstar
Hello everybody!
i just started with my brand new VU+ solo SE v2.
I've installed BH 3.0.2 F .Now I would like to try IPTV on box can someone help me to install it and get it work?
i just need the plugin i can use and how i install it
thanks
HELLO HAMEDSTAR
I've just bought a new VU+ solo SE v2. a clon not original I bought it from aliexpress
and the enigma is openpli 4.0
can I install the black hole BH 3.0.2 F like you did
pleas tell me how to install it .
thanks
HELLO HAMEDSTAR
thanks
hi how are halim, first of all congratulation for your box
1- download the image
2- flash usb format in fat 32
3-unzip the image and copy folder name vuplus direct to usb
4- make sure that folder image name is vuplus
Flashing the Receiver.
– Fully power the receiver down by the toggle switch at the rear of the receiver.
– Make sure no USB devices are plugged into the receiver at this point.
– Insert the USB stick containing the image files into the USB port on the receiver.
– Power the receiver on.
– The Blue L.E.D will quickly flash two or three times then start to fade in and out slowly.
– Once completed the Blue L.E.D will flash rapidly.
– If in doubt leave the receiver for a full 10 minutes before powering down and removing the
USB stick.
any question just send me make
but i did not that you receiver support this image or not
please tell me the how much is your receiver.
HELLO HAMEDSTAR
thanks
No support for clones on this board (read the rules that you agreed to when you signed up on here).
First and last warning.
