Moderator
Ok, Halus61 picons 220x132 transparent ones are great.
By the away, have you upadated yet LCD4Linux ( plugin ) to Ver 4.5R3 from 28/03/2015 on your VU+ Duo2?
Ok, Halus61 picons 220x132 transparente ones are great.
By the away, have you upadated yet LCD4Linux ( plugin ) on your VU+ Duo2?
No I have not
I do not need because I have long , what I need in LCD
Only for let you Know, i´ve tested yet, it´s impossible to install it by ipk, i have to made it by hand.
On the skins maded by you ( superb ones ), there are an overlay on the LCD4Linux skin control, i´m refering to that:
See link: http://www.vuplus-community.net/boa...lcd-display-layouts.13520/page-16#post-160480
The overlay that exist is: The pig overlays the control on the menus.
Just for let you know!
thanks in advance
Goodnight
Sorry my friend,
This I did not understand.
Can you put shot
I do not know which version this relates.
because I really do not have time to test all changes in Lcd4Linux
I'm interested only in the official version which we use inside the image.
Rgd MX
Hi Matrix
Here is the screenshot as i told that refers to last version of ... in time 28/02/2015 ---> LCD4Linux Ver 4.5R3
Note: Test only when you can ... don´t worry ... the LCD4Linux on image works like a charm!
This is a problem that should fix plugin author
I have make fix in BH image
but only good solution is if the author make permanent fix in plugin python coding.
Ok thanks Matrix ... I´ll report that to joergm6
Thanks in advance
