HQ3
You did a great job MX, the skin is so beautiful!
In my opinion, as the design is mostly flat, changing the color buttons to flat style may not be a bad idea. And in System Info, the text is centered (as always), what about the labels on the left and percentages on the right?
the buttons are the same flat stayle the only effect around is " 3d"
which gives them a special look.
Probably flat not look so nice, maybe more fits to other graphics.
But i will not change them because I like look :D
About sys info
both have plus and minus
one is more text info (the left) because it can not be separated info label and percentages.
Centered is more imaginary instrument.
But that all may change later
including all colors of the skin
It is important to get good coding inside skin but also inside image
for this 1920 X 1200 format
For skinner there are two panels that is very difficult to make
(to make good, Black skins hides all errors and bugs :D :chair:)
One is Black Hole system panel
and other MyTube plugin panel.
MyTube Plugin panel are actually three panels in one plus keyboard
And they are coded separately but are displayed as one
Main Panel, Search Panel and History Panel.
result
Main
Search
History
Ah Dzoni
Black darkness hides all also bugs in skin.
When you make a skin like this then you see all.
This is not a skin to compare because is no skin to be compared with this skin.
At least not to my knowledge.
But let's stay within topic.
Some other panels.
Hi
Matrix
Just one question:
Is it possible to had on OSD Setttings a new context menu or submenu that, we can control the VFD skin on Vu+ Duo2.
Best regards,
Hi
Matrix
Just one question:
Best regards,
I do not know what kind of control
If your question relates to the VFD LCD skin.
But I would ask you to start another topic about VFD LCD display.
