http server
opkg list-installed | grep light
lighttpd-dbg - 1.4.30-r4
lighttpd-doc - 1.4.30-r4
lighttpd-module-access - 1.4.30-r4
lighttpd-module-accesslog - 1.4.30-r4
lighttpd-module-alias - 1.4.30-r4
lighttpd-module-auth - 1.4.30-r4
lighttpd-module-cgi - 1.4.30-r4
lighttpd-module-cml - 1.4.30-r4
lighttpd-module-compress - 1.4.30-r4
lighttpd-module-dirlisting - 1.4.30-r4
lighttpd-module-evasive - 1.4.30-r4
lighttpd-module-evhost - 1.4.30-r4
lighttpd-module-expire - 1.4.30-r4
lighttpd-module-extforward - 1.4.30-r4
lighttpd-module-fastcgi - 1.4.30-r4
lighttpd-module-flv-streaming - 1.4.30-r4
lighttpd-module-indexfile - 1.4.30-r4
lighttpd-module-magnet - 1.4.30-r4
lighttpd-module-mysql-vhost - 1.4.30-r4
lighttpd-module-proxy - 1.4.30-r4
lighttpd-module-redirect - 1.4.30-r4
lighttpd-module-rewrite - 1.4.30-r4
lighttpd-module-rrdtool - 1.4.30-r4
lighttpd-module-scgi - 1.4.30-r4
lighttpd-module-secdownload - 1.4.30-r4
lighttpd-module-setenv - 1.4.30-r4
lighttpd-module-simple-vhost - 1.4.30-r4
lighttpd-module-ssi - 1.4.30-r4
lighttpd-module-staticfile - 1.4.30-r4
lighttpd-module-status - 1.4.30-r4
lighttpd-module-trigger-b4-dl - 1.4.30-r4
lighttpd-module-userdir - 1.4.30-r4
lighttpd-module-usertrack - 1.4.30-r4
lighttpd-module-webdav - 1.4.30-r4
As you can see, there is no lighttpd - 1.4.30-r4 package installed, so please read this thread from the beginning, there is problem with dependencies on dbg package, so remove dbg and install lighttpd package, and everything should be ok :-)
yes got now other problems, but it works
need to check the system:
Restarting Lighttpd Web Server: no /usr/sbin/lighttpd found; none killed
2014-10-22 22:22:08: (network.c.371) can't bind to port: 80 Address already in use
127.0.0.1:80 0.0.0.0:* LISTEN 881/enigma2
so this are other problems :D
I don't know what is your problem but i have all ok :-)
Starting Lighttpd Web Server: lighttpd.
root@vusolo2:~# /etc/init.d/lighttpd restart
Restarting Lighttpd Web Server: stopped /usr/sbin/lighttpd (pid 16366)
lighttpd.
Restarting Lighttpd Web Server: stopped /usr/sbin/lighttpd (pid 16441)
lighttpd.
