I need advice
If you are in the UK then use World of Satellite or Goldwafers, I have used both and the they will put on any image you want and only sell original VU+ products.
Right, but I would never be a guinea pig...;)
yes, youre so right
so...my new problem...where can I get a vu+solo 2 box that is just ready to plug in and use. I really am not confident enough to be downloading images/gifts/plug-ins etc
im assuming the trusted sellers don't do this :/
In UK, I know this seller, every configuration and setup:
http://www.world-of-satellite.co.uk/Digital-Satellite-Receivers/Vu/VU-Solo-2-Solo2-Twin-Tuner-DVB-S2-HD-Enigma2-Linux-Satellite-Receiver
Thank you for that eragon.
so, will they install the channels (the 'gift'), so I can just plug it in and watch? is that what the 'image' does?
No genuine seller will supply a box with a gift!!!!!
This is also on the edge of our board rules so refrain from any more chat about that please.
If that is all that interests you then it does not matter what box you get and you wont require anything from a hobbyist board like this.
Kerry, contact them for any legal request.
But you know, in this field the time will come very soon when you'll have to update and reconfigure your receiver by yourself... very very soon... just start now to learn the basics.
sorry arturius :( didn't realise
thankyou eragon...im working on it but its scaring me more and more (and giving me an almighty headache!) :grin:
maybe im looking at a too complicated receiver :/
can anyone recommend a decent twin tuner one (I need the recording facility) please?
Basically, every Vu+ with the BlackHole image show the same interface and configuration menu, so apart from the number and type of available tuners, there are no significant differences in setup.
Performance (and extensibility) is obviously the difference between cheap and expensive models.
Basically, every Vu+ with the BlackHole image show the same interface and configuration menu, so apart the number and type of available tuners, there are no significant differences in setup.
looks like I need to get learning then!
thankyou Eragon, you have been really helpful :D
