I do not have enough space on the internal memory of the device can no longer add any extras and always show a green screen ..... I hope the solution and how to reduce internal memory ... and thanked
It' s really easy to use universes.
Plug in a usb-stick (or partition with the wizard the one you already use), mount it as /universe in Device Manager and then "jump" to Avalon...
You will end up with unlimited space for addons...
