I need help
jity
how can use zero number to recall as old image not to first channel in my list!!
I want it as recall the pass channel I was in .. Thanks .
Moderator
This is not a tool and not settings. You don´t make any reference to your STB model and even to the release image version you are using.
:offtopic:Open a thread on the section of your STB and installed image!
