Icefilms (1.6.0) manual install
There are free ones try googling 000webhost for one they are good..........there are free vpns as well.There are a couple of files s you need to upload to the site theres a how to as well.......google them dont think I can upload them here
Thanks...could you send in private message.
I have a problem with Media Player and XBMC where I can't play MP4 videos. I think it's something to do with the x264 codec. Has anybody else come across this?
many thanks for your work
i have a problem with icefilm plugin
it is working , but when i try to open series seasons to watch i get script error
but this is not happening on movies just on tv series
what should i do to solve this problem?
Me too, any idea how to solve? I`m using a 2 solo se v2 with blackhole 3.0.2E in one and in the other OpenBH0.4
Hi
Have you try it on your PC too? cause i get
on my PC the error Massage that the Plugin is :
"Marked as incompatible or defect"
may that be the Reason ?
Edit:
Forgot to say that i Test it with Jarvis 16.1
Hi
2nd Edit:
Tested it now with Kodi 17 Krypton and with 2 diffrent
Repository´s : Fusion and SuperRepo only thing i can say is
that the Plugin Icefilm dosn´t Work on my PC so it´s not
an Blackhole Image fault but rather an plugin error
