IPTV Channel Updater
@cyborgpunte do you mean me?
@seagate1 but that's not the plugin lol
not all hold left for ever
@marcosturo What OE is it with you?
I belief you have OE 1.6, if so can forget.
can you or someone else explain ( but that's not the plugin ) i thought it was it shows up in green button iptv rev 80 and the new interface much better to work so i'm sorry i don't understand your reply so what i installed.
Hi sat gr,
I need some help, because I'm trying to do all the things informed here, but here's the output when I try to install this package:
root@azboxhd:/var/volatile/tmp# opkg install --force-depends enigma2-plugin-exte
nsions-iptv-list-updater_0.70_all.ipk
Installing enigma2-plugin-extensions-iptv-list-updater (0.70) to root...
Checking for an older version of IPTV List Updater in the system...
An older version of IPTV List Updater was found and removed
Proceeding to installation...
Configuring enigma2-plugin-extensions-iptv-list-updater.
* IPTV List Updater installed *
* Restart the Engima2 GUI to activate the plugin *
Collected errors:
* satisfy_dependencies_for: Cannot satisfy the following dependencies for enigma2-pl
* librtmp-bin * azboxhd login: root
root@azboxhd:~#
After this, of course, I restart the gui and / or the receiver (AZBox Premium HD + with OpenRSI and Kernel 3.3.1, but nothing happens.
i got that information, i also installed the files rebooted stb and theres the plugin, green button plugins. thats how did it . stb solo2 bh ver 2.0.3
Yes, the same is only a small change made ​​by someone and not by the makers of this plugin,
the new version come soon.
Don't follow you
Are you the author of the soft ??
Or are you uploading the soft without permission,
knowing that's not the origin ??
What you can not follow?
I'm also not so vaguely written,
no I'm not the author, and I may because of the author allows all
And I have no idea what you As for the slow
have fun with the plugin and is good lol.
No worries,
but I have difficulties to understand your english.
I suppose you're using g**gle translate or similar.
have a nice day
Bis nobody mit neue version fertig wird diese dateien könnt ihr unzippen und per ftp
usr\lib\enigma2\python\Plugins\Extensions\IPTV-List-Updater\scripts
einfügen und chmodd 755
Albanische, Cekei, Ukraina, Japan Bukets
Up with nobody new version is ready can you unzip these files and ftp
usr\lib\enigma2\python\Plugins\Extensions\IPTV List Updater\scripts
Insert and chmodd 755
Albanian, Cekei, Ukraine, Japan Bukets
thx HasBahCa
  • scripts.rar
    scripts.rar
Hi Guys
I have been using the IPTV list updater Plugin 0.8 and 0.9 and all was working fine including Filmon. The channels were opening fast but after the updated from 0.9 to 1.0 version, there is a lag and the channels dont open.
B-t-w, can I go back to Ver. 0.9 which was working fine?
Any help appreciated.
Tks
Supermario
VU+duo with BH 2.0.3
Hi Guys
Tks
Supermario
just uninstall plugin or delete v:1.0 then re install v:09
can someone explain me why i can't record any programs in my hard disk from this iptv channels??' ....
thanks..
