I have been using Blackhole with a Vu Duo and a Nova-T USB for the Irish DTT called Saorview for several months without any problems. Recently the EPG has stopped downloading correctly. This is more than likely a change by the provider. Normally when 1 of the DTT channels are selected the EPG for the week will download(DVB EIT). Now there are gaps in the EPG schedule. It has been reported that the Language descriptor has been changed from "eng" to "ENG". Would this change cause the gaps in the EPG scehdule? Can anyone help fix this issue?
