is it possible to move .kodi folder to /media/usb folder?
vufun
vu solo2 without any hd installed.
I use a 8 gb flash usb formatted as sda1 (1 gb) mounted as /universe (to enlarge flash memory)
and sda2 (7 gb) mounted as media/usb (to store picons, epg)
so I wanted to copy .kodi folder in media/usb but this solution cannot make work kodi
because as I've understood the folder (.Kodi) need to be stored in media/hdd
so my question is : isn't possible to make kodi point to media/usb (changing this preference in some .ini file)?
or should be forced to format flash usb with 3 partition /universe , /media/usb , /media/hdd ?
consider as well that I want only use back usb port and the second back is already used by a dvbt dongle
and for now I'm not considering to buy an internal ssd or hdd
tnx to all in advance
p.s. I've digged the forums but never find other with my need .Am I the first?
should be happy to make knoledge for others
cheers
