superplakis
the question...tunner c & d?
is possible ministick & avermedia black volar working simultaneously
any new of that?
thanks a lot
-Daviz
Hello, and happy new year
Any new`s of that???
thanks a lot!This evening I will test the new drivers and your request but in the changelog none is specified about that functionality.
Could some one give me a hint on how to enable (in telnet) a second DVB-T tuner?hahahaha by asking!!!
I've two AF9015 sticks which are both are reconized by the box but NOT visable in the GUI :-(
I guess that the second tuner should be started with someting like:
/usr/bin/usbtuner –n /dev/dvb/adapter2/frontend0
But that seems not to be enough to get the 2nd stick working :-(
Can anybody give me the correct cmd?
Ok, thanks for the reply! (That saves me also from buying a other brand DVB stick )At the moment the 2nd DVB-T tuner support is not supported.
At the moment I am able to have 2 usb dtt but they are not reliable, yet. I enabled them manually.
I've tested the usage of 2 DVB-T USB devices but the second doesen't work correctly.
Can you share more details on your findings ? Is it a real complex problem ?
Thanks in advance for sharing your learnings and for the key contributions you are making to the community.
When I enable the two adapters manually, the second DVB USB device is correctly detected but doesen't work correctly when a service scan is launched on D tuner.
The problem is already reported to VuPlus Dev Team with a detailed log.
hello
i see in the vu+solo that the firmware allow to use two usb tuners, in future versión the vu+duo allow this????
thanks
