Latest Drivers for Vu+
When are VU Plus going to fix the driver problems with the UNO?
When using Inverto or Triax LNB and watching DVB-S2 channels where there are channels on both Vertical and Horizontal polarisation using the same frequency, transponder LOCKING keeps falling out in Windy conditions or by gently shaking the Sat dish! Only LNB I found working without this issue is MegaSAT Diavolo.
Anyone know how to report this to VU Plus without ending up in the big pile of complaints?
The new kernell dont work as good as the previus kernell on vu+solo2. The ram in use is very high. For example, when you put an pip picture and you hold down the up or down keys to to move for de channel list, the selection bar jumping contantly, while on the previus kernell was moved very fluid.
Regards from Spain!
