a911
The BH Lover
Notepad++ 6.1.3
Changes in 6.1.3:-
-Enhance the performance issue for xml matching tags highlighting and for displaying clickable links.
-While the amount of file to open is larger than 200, a dialog will be shown to warn user.
-Fix Notepad++ close bug while move one cloned new empty document into another view, in the destination contained only this new empty document.
-Fix hanging problem while double-click on a project folder then (immediately) drag it.
-Fix a bug while command argument contain an empty string ("").
-Fix mouse cursor disappearing bug on right click while a project item is dragging.
RgdZ
a911
Changes in 6.1.3:-
RgdZ
a911
