Hi again,
I've been focusing on Bouquets and not on PIP as I thought it was working but now for some reason I cant get any PIP channels again. As the channel selection would be too limited anyway, I gave up on the one cable solution and as the Triple LNB Quad box has 4 outputs, I connected the second cable to tuner A again (as also mentioned above didn't work then either for some reason) and changed the config accordingly so each tuner can access the 3 satellites.
PIP is just not working.
I'm at a loss. With two cables connected and each tuner configured individually for 4 (or 3 connected in my case) DiSEqC's, should I not be able to record a channel and see everything else?
I started testing again and disconnected tuner A and reconfigured B as loopback. Regardless of satellite or polarisation, PIP does not function.
Each cable and each tuner work individually though.
What to do?
What to do?
