Mediaportal-Plugin
habe nun sämtliche Zugehörigkeiten installiert , aber es will einfach nicht installiert werden
hat noch jemand ein tipp für mich ,
danke im vorraus
"opkg install python-argparse" über Telnet eimgeben und installieren und anschließend Receiver neu starten. Danach läuft das Portal wieder ;)
neues Update auf 7.3.5 online verfügbar
für die jenigen wo dann das Plugin nicht angezeigt wird folgendes dann
Datei entpacken und nach /usr/lib/python2.7 kopieren rechte 644
Gui Neustart und danach sollte es in Erweiterungen angezeigt werden
Neues update auf v7.4.1 online verfügbar
fun.autobild" "740" "Fixed with release 7.4.0"
"mediatheken.srf" "740" "Fixed with release 7.4.0"
"sport.ran" "740" "Fixed with release 7.4.0"
"porn.beeg" "740" "Fixed with release 7.4.0"
"porn.eporner" "740" "Fixed with release 7.4.0"
"grauzone.hdfilme" "740" "Fixed with release 7.4.0"
"grauzone.serienstream" "740" "Fixed with release 7.4.0"
"fun.filmon" "740" "Fixed with release 7.4.0"
"music.nuna" "740" "Fixed with release 7.4.0"
"porn.wtfvideofree" "740" "Fixed with release 7.4.0"
"fun.wissen" "740" "Fixed with release 7.4.0"
"sport.wrestlingnetwork" "740" "Fixed with release 7.4.0"
"porn.sexu" "740" "Fixed with release 7.4.0"
"sport.sport1fm" "9999" "Not fixed"
"porn.xxxart" "9999" "Website is currently offline."
"sport.laola1" "9999" "Not fixed, complete rewrite necessary."
"fun.auditv" "9999" "Not fixed, complete rewrite necessary."
"grauzone.seriesever" "9999" "Won't fix, removed with MP release 7.4.0"
"grauzone.moviesever" "9999" "Won't fix, removed with MP release 7.4.0"
"porn.gstreaminxxx" "8888" "Website is offline, removed with MP release 7.4.0"
"porn.playporn" "8888" "Website is offline, removed with MP release 7.4.0"
"grauzone.serienbz" "8888" "Website is offline, removed with MP release 7.4.0"
"grauzone.watchseriesonline" "8888" "Work in progress
soory my friend i don't undestand please explain thanks.
when i want to erase it i found mediaportal but not in plugin
schau nach ob du mediaportal in usr/lib /enigma2/python/extensions vorhanden ist und wenn ja dann die argparse Datei einfügen wie ich den pfad angab
gruß
Versuche das argparse zu installieren nachdem du auf 7.42 geupdated hast, wie bodo es in ein par Einträgen vorher beschrieben hat,dann sollte es gehen
Kann mir jemand helfen?
Habe eine VU+ Duo2, Update wurde gemacht auf 7.4.5 Mediaportal funktioniert alles bis auf Burning-Series.
Fehler bei der Installation wurden keine angezeigt. Im Portal selbst wird auch 7.4.5 angeigt.
Habe über die Box Mediaportal entfernt auch wieder installiert, aber leiider das gleiche Problem alles funktioniert einwandfrei bis auf Burning-Series.
Kenn jemand das Problem? Habe schon gesucht aber noch keinen Beitrag gefunden mit dem selben Problem.
