You can test Pli image (use MiniDlna) or something else (i don't remember) that use Ushare.
We have tested both but are poor.
MiniDlna is good for tv compatibility but the m3u stream don't work.
Mediatomb is better because stream works between boxes Pc and Ps3.
No i think is not a good idea to use solo for Mediatomb DLNA server.
Not enough memory and cpu power.
Better that you use your Pc for Dlna server.
Install the hard disk in your Pc and mount it in solo so you can record on your server hdd.
