Mistakes to be corrected
niglou
BH Lover
As I am translating into french the new image, I found some mistakes :
In BhRed.pyo
From red button , choice big bang
Last line of message box Bing bang instead of Big Bang
Also
Sorry your Parallel Universes are older than your Black Hole world
You need to re-inizialize the system, reformat your Usb stick or generate a Bing Bang.
Also
The Big Bang will collapse all of the Parallel Universes into the original Black Hole matrix
This means that all of your Parallel Universes will be destroyed and turned back into Black Hole timespace.
Are you sure you want to start the Bing Bang?
Also
Warning, all of the data stored in your Parallel Universes will be lost.
Also
Black Hole details:
Black Hole is the original matrix of all Parallel Universes and resides in its own phisycal space.
Also
2) Map the newly formatted stick to "universe"
sign " non accepted by po edit replace with '
