When you are viewing the channel list, you have to select a channel and press the remote menu button.Hi
Is there any possibility to move channels within the list at the box level or do linux boxes not support such lame functions from cheap receivers? Also how to add to favourites?
Thanks
Andy
Hi
Thanks
Andy
Yes its possyble. First Open channel list,Choose your channel you want to move in forward or backward, press the menu button go to, enable move mode, press OK button, choose channel, press OK,then use the middle button up and down by moving the position of the channels that you want, press the OK button again. thats all.
2. To add channel to ur favorits, Open channel list, press home button, go to add service to bouguet,press OK button and choose ur favorite
PS: Sorry for bad English, but I am Bulgarian. Cheers.
Channel key +, then cursor on channel which you want delete, then key MENU and choose actionhi. how can I delete a channel from list? my image is blackhole ver.1-6-5
