MX HD
No that is not the reason
I will change the font if it is better
But I will not change because it is different.
As you know I have tested many fonts
and they all have their pluses and minuses.
This font remains the best.
But if you've got some better, and you convince me that it is so
I'll try it.
Agn change :chair:
As you know plugin Coders only know about the black backgrounds and white fonts :eek:
I have to make agn big changes in skin coding and graphic , so that it is completely under my control
and we can use now and later all colors in skins and not only black/dark backgrounds and white fonts .
As I guess you are developing a whole family of this skin like eclipse (blue, red, black, epg or not on second infobar..), I am wandering as a lot of stuff is common to all skins, if it would be possible to release a single skin with different options in a menue ?
Yes I know....2 or 3 more modifications :grin: but would be really sensational !
The problem is that the additions and plugins were based
on the use of dark skin and black background with white fonts.
So it is impossible to use a light background and different colored letters
with classical skin coding.
Namely, if I use black letters, the plugin will also use black font
But on a dark background.
Or example
or, say, plugin white letters on my skin light background. etc
The whole concept of coding in plugins and addons is based on a black/dark background
and limiting coding and graphic in skins.
But I think I'll make a totally independent coding that will allow the use of light background and dark letters
This is now the strongest coding,
for the next generation of boxes and skins.
Skin coding Supports all colors ,
and is independent of the plugins and addons coding and colors.
Which basically means that we no longer need to use these dark skins.
We can now use any combination of colors.
Or otherwise
addons and plugins are not dependent on main skin coding.
Which is mainly based on the black background color and white fonts.
