Thank you for the quick response...You can make any picon to be default picon
if you rename picon in to picon_default.png and copy
in to MX HD4 skin folder
The white on Menu is bad it should be dark so its more visible without strain.
I am using latest 1.79 and many I downloaded it says incompatiable 1.7x
THANK YOU MATRİXBeautiful. My favourites MX HD:
- MX HD2
- MX HD4
Thank you Matrix10![]()
