MX i6 & MX i6+
thanks matrix10 good skin, but 2. screenshot is legal ? because nagravision crypt.. :)
edit mx no need to quote
As much as good they look all your skins look pretty similar to me.
If you don't change things and you keep doing them just for your taste, they will look like all similar in the end. I mean, you're the only one making full HD skins for BH, if we want different skin looks we don't have much of a choice.
I don't want to sound rude, I just think it would be good for OBH and BH images if we have more different skins.
not exactly.
I do know how much and what kind of skins we have for Enigma2
you're looking for a variety of skins, or you're looking for quality skins ??
We make quality skins not the skins with every day different colors and poor coding and performance.
In addition we have original and different skins on the server but also some on the forum.
Good skin and coding for it
as well the skin without major bugs or without is the time-consuming task.
All of them layout are similar to each other.
Skins with Pig or no , big , black and white e.t.c
What is normal and it is not a plane construction.
It shows what the skin needs to show.
But there is another big difference and it is the speed and performance,
readability and visibility .
And this have a very small number of skins.
but feel free to make one skin for us
or you have a choice to use another image that gives you the graphics of your choice.
not exactly.
Nevermind, you're the boss!!
I actually edited all the skins I've use(d), I just wanted to see anything more than white white more white and blue!
And yes, I thought about install openpli since oBH doesn't offer much more, still no worth the time right now, I'm too busy!
Finally, thanks for your work and time, don't be mad just because I completely disagree with you!
It would be good to show the CPU temperature and hard disk,once again not to push buttons.Many people who live in hot countries would support me with my opinion.
Im sorry ,
Unfortunately I have opposite opinion.
temperature of my box and HDD have no greater variation than a few degrees
for it we really doe not need a constant meter in OSD.
These are things that do not change so quickly in order to place them in the main OSD
and at the same Time affect the speed and performance.
Of course if you live in a hot climate
Cooling must be more.
In addition we have a plugin that automatically regulates it.
Also I do not like overcrowded OSD .
rgd MX
Unfortunately our views differ
I do not like skins with many colors and colored letters.
But I do not think we should all use and love my skins.
