MX Maestra OBH skins
A new series of MX Maestra skins for Open Black Hole
You can download from the OBH image server
OpenBlackHole-Skins MX_Maestra2 C OpenBH 1.X (Format 1920 x 1080)
OpenBlackHole-Skins MX_Maestra2 OpenBH 1.X (Format 1920 x 1080)
OpenBlackHole-Skins MX_Maestra Black OpenBH 1.X (Format 1920 x 1080)
how can I reset for skin
After downloading the skin from our server, just press OK on your RCU ( Remote Control Unit ).
After restarting GUI ( enigma2 )
Press Menu > Setup > System > User Interface > Skins and apply the downloaded ( new installed ) skin.
By far the most beautiful skin. The detailed bar on second click might be placed below the screen instead of above.
Thank you once more for this amazing skin that continues to be my favorite, now that I'm on OBH as well.
However, while trying to make my few personal modifications, I noticed that three 'widgets' in BH (netcard_info, orbital_pos, and nfreq_info) have all been replaced by "PliExtraInfo" (TransponderInfo) which is less informative and flexible. I'd like to ask if it's possible to utilize those widgets in OBH too, as I used to distribute them in various parts of infobar with different colors. :)
Thanks in advance for any help.
A question to Matrix10: Is there any difference between 1.0 and 4.1 regarding Maestra 2C skin?
I have a customised skin.xml from 1.0, can I use it in version 4.1?
