MX Maestra OBH skins
Update all MX Maestra Weather skins
Change in Iptv OSD (removed SNR from Iptv OSD)
added Hi Fi icon
add network speed (recive/transmit download/upload) in movie player
etc
New version
MX Maestra2 Black Weather
old version deleted from OBH server
support for Weather plugin in second infobar OSD
You can download from OBH image server
you have to install first weather plugin
Green button>>Addons>>Addons Download Manager>>..Plugins>> weather plugin
In weatherplugin (green panel) set your city and city code with Menu and yellow button
Added new Plugin for Weather >> Weather Plugin v1.2
Download from Black Hole and Open Black Hole image server.
If you use plugin with skins with weather support
In weatherplugin (green panel) set your city and city code with Menu and yellow buttons
New Plugin panels
added Hi Fi icon
etc
Thank you for the skin .. I have problem I wish you can help me .. The network speed in info bad in MB work fine but when I download plugin call "XC Plugin" they changed from MB to KB/s and looks really bad how can I change them back to MB ? Thank you so much I need them MB with "XC plugin".
I do not know that
this is a question for the plugin author,
If I understand your question the problem is not related to the skin.
Why don't you use the appropriate plugin? It works perfectly.
Instead, making an image heavier just for this task, wouldn't make happy the rest of users. I use, sometimes, the bitrate, just for curiosity. But I don't believe that the majority of people do the same.
Guarda che questa è la sezione internazionale ;) Only English here, please!
And consider that not everything we talk about in this forum is related ONLY to VU+, BH or OBH. So, you need just a simple Internet search to get the answer.
Bitrate is a common term related to video quality.
Alexwilmac thank you for your answer. I use, sometimes, the bitrate too but, I do not understand the reason why to be there if isn't running :)
I think is good to activate it to be running, and the users can having the choice if they want it to be active or inactive.
If you were thinking about the plugin.
How Much I Know Bitrate works on all boxes except for Zero 4K
How I know it does not work on any image for Zero 4K
And that is not a problem for our team.
We're not plugin authors.
Hello
My skin is MX_Maestra2b_weather
In Vortual Keyboard i think missing 2 colums at right = and del
Thanks
Hall
OE-A they changed coding.
And I only have two hands and 60+ skins for BH and OBH
Soon I'll need 24 hours to code my skins .
:help:
They will be fixed
until then use, the default skin to be updated soon
or some of the MX Sea skins that have been updated.
I am talking about this skin. I just trying to make to run the bitrate.
I have vusolo2 with the latest obh
It's not a bitrate viewer for stream from the satellite
but network speed upload and download.
everything that goes through a network connection also Iptv and video streaming.
Our skins have no coding inside skin coding and OSD for SAT bitrate viewer
you have to use a plugin bitrate viewer for that.
