MX Sline / Slim Line
Infobar menu etc etc with 75 or 50% transparency, like an army one.
Inviato dal mio MI 11 utilizzando Tapatalk
You can change the transparency in A / V Settings
for each skin.
Not all skins are good with transparency.
You're losing detail.
In addition skins with PIG (small TV monitor in the panel) can't use transparency in this panels
with PIG.
Try with these latest NP skins
Transparency works
for each skin.
with PIG.
Transparency works
Yes, I know but having one created directly subjectively would be ideal. From the settings it's ok for BH but it can't be done on the OBH.
OBH
Of course you can.
Skin Setup >> OSD Position >> User Interface visibility
You're right, sometimes I browse the menu a little .
It is positioned differently than the BH.
(Another Open is in the same place as the BH.)
However, the rest of my idea, it is another thing a transparent of his.
all Dots skins update
You can download skins from BH image / skin server
Change Channel Selection panel
added 3 next event names
Ho una Vu + Duo4kse con BH 3.1.0 e ho installato la skin Mx Slim Line NP-I ho un problema, nella lista dei tuner vedo solo quelli che sono accesi (verde) non vedo i tuner che sono spenti (grigi) come nelle tue immagini. Pubblico una foto della mia pelle per farvela vedere
