MX Sline / Slim Line
And in the black and grey versions?
One suggestion: reduce the size of the next event and/ or change the color to grey, for example.
I like the PIG in dark blue version.
Regards
Regards
It's not possible to make different OSD for all
Some boxes have greater transparency and others have smaller ones.
Some users want more and others less transparency.
The transparency regulation should be within the image and not within skin.
Which means that the skin should use less transparency
so that users can regulate transparency on their own.
The problem is that regulation of transparency does not work anymore.
For what should be reported BUG with VU +.
Where is this ? Which skin??,
OSD ?? Channelselection ??
The same goes for event info.
There are different user desires.
I mean change the color and the size of the "next event" in infobar (i think you call it OSD). The color could be the blue like the image attached. In my opinion it is more important to highlight the current event.
regards
regards
Possible
The problem is that the gray color is not good on a blue background
maybe blue as in the channel list.
It does not matter to me personally that they are the same colors because I always looking at the first line for the current event.
Transparency of the skin can be regulated in the Open Black Hole
in Skin setup panel >> OSD position >> User interface visibility
Me too: it's much more clear to read only and just the active tuners, instead of the need of 3 colours to understand which is active, which is not and which is recording.
