MX X Line
Clearer, as wrote Matrix10, can not write - skins are 1280 pixels wide and 720 pixels height. It is Full HD or not? ;) If you need FHD, I think you know it
Nice answer.... ??????????
I think is not hard to read.
The skins in BlackHole and OpenBh servers ( @Matrix10 ones ) are all identifyed the image version image you can use it and the resolution they are developed.
HD skins ( 1280x720 ) are identifyed this way.
FullHD skins ( 1920x1080 ), as this.
If you use AV resolution 1920x1080, you can use a 1280x720 that will fit the entire screen as well.
The only problem, and this i have already answer you --> http://www.vuplus-community.net/board/threads/mx-x-line.18725/page-2#post-214521, the skin is not compatible with OpenBH 06.
I don't think too, @Matrix10 will readapt this skin for that image ( because there are probably more than 400 pannels to code, and this is a hard job that wastes a lot of time )
In OpenBH 06 skins server there are only FullHD skins ( 1920x1080 resolution ).
