MX_HQ9 & MXHQ9B & MX_HQ9W
Dein Skin sieht wieder mal super aus, habe trotzdem mal eine bitte , wie sieht es aus , das man eine Picon Größe von 400*170 ein bauen könnte?
Entschuldige das ich Deutsch schreibe, aber mein Englisch ist mies.
Danke
Skin is not finished yet and will be in the next BH / OBH image.
bodo1960 Picon Größe von 400*170 is to big for this skin.
Maybe i can make some sub version , not sure I have to test.
but first I have lots of coding in this one .
Hello,
AMC is very nice. We hope to have the subtitles automatically when playing a video. So we do not need to have the media player2. With the Customize Channel List Cursor behavior (keep service) would be good. I also hope that disappears so-called bugs. Youtube TV freezes frequently when pressing exit. I installed BH 3.0.1 and loaded dream explorer. After that the box crashed and I needed to reinstall. I hope that I do not want too much and I know the problems with the encoding. I just want to eliminate the small things that prevent BH image to be perfect.
I hope that my comment will help you and I wish you good luck on this :D
