my VU+ uno with the latest BH software, but after i play on YouTube the box crashes with a green screen, is anyone else having this problem? I have the same issue after 2-3 videos on the VU+ Duo using the same software. Any suggestions for a fix?
The Fix 2 should works fine.hiI did not understand the difference between the first and second fix, which is good for my box vu+ solo ?
new to this ... iv downloaded the fix from addons then restarted the box but still getting green screen on youtube iv i missed something cheers
You need to have installed Black Hole 1.7.8 for this fix.tried 4 times turned the box off at the mains still green screen cheers
